No signal to fuel pump
Old Sep 27, 2006 | 08:48 PM
Stumpjumper's Avatar
Stumpjumper
Default No signal to fuel pump
Hey everyone. I've got a 1989 B150 with a 318 with TBI and am having a problem with the fuel pump. I removed it from the tank and benched tested it and it works fine. I then got out the trusty test light and discovered that I am not getting any power to the pump. I checked the fuse block and everything appears to be ok. I don't have the owners manual so I don't even have a clue if any of them are for the pump or not. My question is, does any one know if this beast has a fuse under the dash or possibly a fuel pump relay under the hood. If so an aproximate location would be greatly appreciated. Thanks
Old Oct 15, 2006 | 06:54 AM
IGadget's Avatar
IGadget
Default RE: No signal to fuel pump
if you cant afford anything else, Id suggest $20 for a Haynes manual. Even if the color codes are not 100% correct, at least it usually gets where the wires go correct.
