need help with ignition coil location. 03 dodge 1500
i own a 2003 dodge ram 1500 van V8 and the problem is i need to replace the coil of cylinder #6 and i dont have any idea where cylinder 6 is located. does anyone have any writes up or diagram? thanks.
OK, when you're looking at the engine from the tiny hood, it will be on the left side. The igniton coil is a littler smaller than a person making a fist. It will have the wire and boot connected at the top too. Either of the V8's have the coil in the same spot.
You could just take the "dog-house" off, look at the ignition cap for the center most wire and boot and follow that wire to the coil. [&:]
