Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Power Wagon ground clearance; is it true?
Old Apr 24, 2007 | 05:39 PM
REDBARON's Avatar
REDBARON
Default Power Wagon ground clearance; is it true?
Hey Everybody,
What are the differences in ground clearance between the Power Wagon and the rest of the Dodge Ram 4X4 line?[>:] I know that the spring rates are different, but are the springs actually higher? From what I've been able to discern, It seems like the Power Wagon is a pair of thirty-three inch tires plus somevery slightly taller front springs, basically a leveling kit with big tires. Barring the ramp-breakover and approach angle, if I leveled the front of my Mega Cab CTD 4X4 and put on some thirty-three inch BFG A/T's would I essentially have the same ground clearances as a Power Wagon?
Just want to have as much ground clearance as I can without exceeding factory specs and thereby voiding the warranty. [:@]
Thanks,
John
P.S. Maybe someone lucky enough to actually own a Power Wagon would be so kind as to actually go out and physically measure; A. The heighth from the edge of the tailgate when open to the ground. B. The distance from the top of the wheel arch of a front and rear wheel respectively to; A. the hub and B. the ground. C. The top center of the front bumper to the ground. Thiswould be very cool.
Old Apr 25, 2007 | 07:04 PM
Drew's Avatar
Drew
Default RE: Power Wagon ground clearance; is it true?
2 inch leveling kit and some 37's will give you all the gorund clerance you need
Old Apr 27, 2007 | 02:18 AM
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
"if I leveled the front of my Mega Cab CTD 4X4 and put on some thirty-three inch BFG A/T's would I essentially have the same ground clearances as a Power Wagon?"
Yes, to the differentials, but you may have a bigger rear axle on your CTD that may afford less clearance there. The rear on a Power Wagon is the AAM 10.5 inch. Is that what you have?
Posted Power Wagon differences here:
https://dodgeforum.com/m_732490/mpag.../tm.htm#732490
