Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
ecm reprogram after battery disconnect?
Old Apr 26, 2007 | 09:43 PM
bandit86's Avatar
bandit86
Default ecm reprogram after battery disconnect?
as an anti theft measure, I was thinking I'd disconnect the ecm feed after every shutdown. simple 2 wire 1 switch. This way my ram v10 would be impossible to steal unless they tow it away. Does the ecm actually keep any usefull info it learns? I know you can clear troublecodes by removing the battery, would it have to re-learn anything?
Old Apr 26, 2007 | 10:33 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Default RE: ecm reprogram after battery disconnect?
Not sure what year truck you have, but the computer in my 01 5.9 resets back to the base code and has top re-learn if it's totally powered down.
Old Apr 27, 2007 | 10:54 AM
crcarch's Avatar
crcarch
I don't think I'd want to reprogram my radio every time I got back in the truck. You might putting a cut-off switch to your fuel pump and achieve the same thing. I have one on my Challenger (Of course, no computer either) and it does the trick.
