Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Best way to remove badges?
Old Sep 12, 2004 | 07:46 PM
QuadzillaStyle's Avatar
QuadzillaStyle
Default Best way to remove badges?
Any advice?
Old Sep 12, 2004 | 07:52 PM
LoNeWuLf's Avatar
LoNeWuLf
Default RE: Best way to remove badges?
heat gun.. or hair dryer..
and an eraser for the sticky crap
something to pry the badges off..
Old Sep 13, 2004 | 05:50 PM
BULLDOG's Avatar
BULLDOG
I don't suggest "prying" the badges or emblems off. You can use a heat gun to soften the tape, usually just direct sunlight works, and then use dental floss, or monofilament (fishing line) to cut and separate the emblem from the body.
You can purchase a glue residue eraser from an auto body supply (maybe even a local parts store) to remove the residual stick stuff. Just make sure you don't spin them too fast.
Old Sep 13, 2004 | 08:21 PM
ramfan5.9's Avatar
ramfan5.9
dental floss or mono and goo gone
Old Sep 13, 2004 | 08:29 PM
356MAGNUM's Avatar
356MAGNUM
The way I did mine was to get goo gone and soak the hell out of the emblems. Then I used a fingernail to lift as the tape got soft. Then used a small piece of wood to brace the emblem up as I continued to soak.
Old Sep 13, 2004 | 08:51 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
I used a heat gun carefully and then some Goo Gone... Several years later I repainted the entire truck... Hahaha!!
~Amanda
Old Sep 13, 2004 | 08:52 PM
swede7000's Avatar
swede7000
Paid my local bodyshop $20 to strip everything. Well worth it since I've peeled them myself in the past. It can be a pain. If you use a heat gun, watch so the paint doesn't bubble.
Old Sep 14, 2004 | 03:57 AM
Yellow Runner's Avatar
Yellow Runner
i used a hair dryer got it hot and then got some small tring (trot line size string) and ran in behind the letter and followed it down till it jsut shot off and then got some carb. cleaner and sprayed on the gooy stuff and got to peeln it wit my fingers and scrubn teh rest off with a dry rag.
