Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Dome Light & Radio Dead???
Old Jan 1, 2004 | 09:29 PM
jrwpmw's Avatar
jrwpmw
Default Dome Light & Radio Dead???
98 Dodge Ram 1500</P>
The Glove Compartment Light broke loose and shorted out, the Radio and Dome lights also went out when that happened - n o problem right... I just disconnected the Glove Compartment Light (never use it anyway) and went to check fuses (in side and under the hood) - but they are all fine! I went over them a second time to be sure, but they look fine? Note, there were a few bigger fuses under the hood. I didn't check them becasue I didn't have a spare, but they seemed to be for bigger items (blower, etc).</P>
Would anybody know what is going on? </P>
Old Jan 1, 2004 | 09:49 PM
Amethyst98Ram's Avatar
Amethyst98Ram
Not sure what they did with the radio wiring but I lost the radio on my 98 when the head light switch had a short in it, I replaced it and the radio came back on, some how they are in the same loop I know this does not answer your posting but maybe other people have had this problem that you are having.
Old Jan 2, 2004 | 02:18 AM
Deviousin10ts's Avatar
Deviousin10ts
I may be wrong as I am so often but:</P>
block 18 a 15 amp fuse controlls interior lamps</P>
block 51 a weird looking one on the far right controls cluster,radio and underhood lamp</P>
block 21 controlls radio amplifier I doubt this one is your problem</P>
hope this helps</P>
</P>
Old Jan 2, 2004 | 12:45 PM
jrwpmw's Avatar
jrwpmw
It turned out to be a 10AMP fuse (Labeled IOD I believe). It's one of those protected fuses with this black covers. I orginally didn't check that one or the air bag ones.</P>
</P>
