Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
synthetic rear end and transfer case oil????
Old Sep 16, 2004 | 08:40 PM
wildwolf59's Avatar
wildwolf59
Default synthetic rear end and transfer case oil????
what is everyone using in their rearends and transfercase......i have already used the mobile one for oil but what about the other two????
Old Sep 18, 2004 | 01:20 AM
dodgemech's Avatar
dodgemech
Default RE: synthetic rear end and transfer case oil????
We use synthetic 75W-140 in all the diffs we build at work. Just regular ATF in the t-case. Transfer cases don't really do anything to demand a synthetic fluid, a waste in my opinion. I have only seen a few fail over my career with Chrysler.
Old Sep 18, 2004 | 12:59 PM
wildwolf59's Avatar
wildwolf59
good enuff dodgemech....i will put that in there then. I seen that at walmart ...the 75w140 but i didnt know if that was the right one but i will use that one and the atf in the transfer case also....the only question i had was the synthetic transmission fluid on what to use, so if you read this again let me know...thanx!!!!
Old Sep 18, 2004 | 06:57 PM
dodgemech's Avatar
dodgemech
I am not a big fan of sythetic trans fluid. It does have much better heat propeties which is important but it gives up quite a bit of friction modifier. Many top trans builders will not honor transmission warranties if synthetic is used. TCI and Hughes are just 2 of them.
