Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
The best Batteries!
Old Sep 25, 2004 | 03:11 PM
Kryabn1's Avatar
Kryabn1
Default The best Batteries!
Hey guys, What is the best batteries? I live in michigan so its cold winters so what batteries to you guys reccommend? Iv always had good luck with A/C Delco.
Old Sep 25, 2004 | 03:43 PM
vlsun's Avatar
vlsun
Default RE: The best Batteries!
optima batteries have pretty good cca's.
Old Sep 25, 2004 | 03:50 PM
flw's Avatar
flw
This is most likely the only area of expertise I have. I worked for Johnson Controls battery division which makes Interstate, Sears, Autozone, Walmart along with many more for seven years.
Two things will kill a lead acid battery, a true frozen battery (destroys the crystals on the plates within each cell, and heat.
I'll give general advice for anyone.
If you live in a area where heat tends to be more of a issue most of the year, you want a battery with fewer plates per cell thus reducing internal battery heat.
If you live in a area where cold tend to be more of a issue most of the year, you want a battery with the the most plates per cell.
So in a hot area a 650 CCA battery will do well. In a cold area a 900 plus CCA battery will do well.
Another cold tip is if possible keep the battery from sitting all night or day in subzero temps. i.e remove it on a as needed basis or park in garage with engine blanket, Oil or radiator fluid heaters will not help your battery directly.
Some will tell you about plate design to create a greater surface area for more paste which would mean more crystals per plate. This is correct but I'd rather have a battery will more plates than "new designed plates".
My 2 cent from working in a acid filled factories.
