Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Transmission dipstick filler tube o-ring
Old Jun 17, 2007 | 10:51 PM
racerseks's Avatar
racerseks
Default Transmission dipstick filler tube o-ring
This is in regard to a 93 Ram. Truthfully, I'm not sure which transmission is in it, but it's got a 3.9 V6, and is an automatic.
The transmission dipstick filler tube is leaking a bit down by the end that goes into the transmission. It's minor, but I wanna go ahead and replace the o-ring. Anyone know how much fluid might come out when I remove the tube?
Thanks!
Old Jun 18, 2007 | 01:00 PM
OldMoparMan's Avatar
OldMoparMan
Default RE: Transmission dipstick filler tube o-ring
ORIGINAL: racerseks
Thanks!
If the engine's off: None.
Besides, the level'sprobably low from leaking......
Usually, a single bolt on the bell housing holds the tube in. It might be a pain to get to. When you drop the new O-ring on and go to put the tube back in the trans,put some grease onthe O-ringso it slides in nice, and doesn't tear again.
