Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Rear turn signal problems
Old Jun 18, 2007 | 09:09 PM
Bossman9784's Avatar
Bossman9784
Default Rear turn signal problems
Hey i need some answers! I was driving along and my blinker in the cab did not flash but remained steady on when making a L turn. So no big deal, I have to replace a bulb. Then, I went to make a R turn and the light also remained on. I now know that neither rear turn signal works but my front turn signals and the dash trun lights come on when the turn signal is activated. It is highly unlikely that it is a buld given that both went at the same time. Also, the fuse is not burn and if it or the turn signal flasher was bad why would the frontcome steady on and the back not light at all? WHERE IS MY PROBLEM?????
Boss
Old Jun 18, 2007 | 09:12 PM
DURTGURL81's Avatar
DURTGURL81
Default RE: Rear turn signal problems
try your blinker relays
Old Jun 18, 2007 | 10:07 PM
DieselDemon's Avatar
DieselDemon
Should we guess on what year and model Ram you have?
You have a bad flasher.
Old Jun 18, 2007 | 10:53 PM
Bossman9784
Sorry I completely forgot to add that. My baby is a 97 1500 4X4 5.9LV8 with 43,500 miles. It probably is a bad flasher unit, ill have to wait till morning to pick one up.
Old Jun 18, 2007 | 11:11 PM
dhvaughan's Avatar
dhvaughan
Q WHERE IS MY PROBLEM?????
A yep. flasher is in the fuse box on end of dash, drivers side.
