Dodge RamThe full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Pulled my K&N and went back to a standard filter. The K&N seemed to cause a loss of low end torgue. Anybody else experience this?
Do you have the Hemi???? If so then it is true for a loss of hp and torque. My 4.7L got some boost from the K&N drop-in not to mention about 2 more mpg....
So, does this apply to all Cold air intakes for the Hemi? or just certain ones? I just purchased a Fuel Injection Performance Kit (FIPK), Generation 2 by K&N, will i have the same problem, and if so is there a work around to correct the mixture issue?
I have one in my Hemi and no problems. and nothing black. better check to see if you guy's installed it correctly. You may not have the filter ailined properly in the box.
