Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
turn signal problems
Old Jan 9, 2004 | 12:09 AM
youwho's Avatar
youwho
Default turn signal problems
hi all, just wondering if anyone had this problem and maybe even fixed it. my turn signal(both sides) start fine, then about half way through the red light, they get slower and eventually staY ON solid. its too cold to go outside to find the problem, so i figured its easier to fish for the answer here. thanks for the help duane
Old Jan 9, 2004 | 12:39 AM
mazz's Avatar
mazz
Might be time to replace the flasher unit. Sometimes they get weak and the problem you are having occurs.
Old Feb 2, 2004 | 10:30 PM
gibetown's Avatar
gibetown
Could anyone please explain how to replace the flasher unit. (I have to do this myself, as my husband broke his hand ) I think I have purchased the correct replacement unit. So now I think I have to remove the bottom casing from the steering wheel--do I have to disable the airbag first?? Once I get past the airbag issue, I think I can get it from there<IMG src=smileys/smiley5.gif border="0"> <edited><editID>gibetown</editID><editDate>38019.8137962963</editDate></edited>
Old Feb 2, 2004 | 10:37 PM
kaostik's Avatar
kaostik
anytime you are working on anything electrical, its always a good idea
to disconnect the battery first. when you are finished fixing whatever it is your attempting to fix,
reconnect the battery, then test the repair it to make sure its working.
<edited><editID>kaostik</editID><editDate>38019.8183796296</editDate></edited>
Old Feb 2, 2004 | 10:40 PM
gibetown's Avatar
gibetown
Will diconnecting the battery then disarm the airbags??? (Sorry I'm so ignorant about these issues) Thanks for your help!!!!!!!!!!!!
