HEMI cam upgrade
Does anyone know if there is a cam upgrade for the HEMI yet? I hate to admit it, but I am starting to get bored with the stock power of my truck. Just wondering if anything is out there to improve hp.
Thanks,
Thanks,
Comp Cams has the cores in and will custom grind one for $320, see comp cams at www.compcams.com. get the phone# for the tech line.
What we need is a HEMI EDIT system for the computer where we can change everything, not just a basic prgmr that only adds 20HP. If we ever get a program like this, you'll forget about the cam most likely.
If you check into the article that popular hot rodding did it shows where each PHR guy got to build their own HEMI engine and put it on the dyno and see it perform, the one PHR guy was reporting his engine dyno was showing way over 400 HP at the crank, keep in mind these engines are unrestricted when in the DC test facility on the engine dyno........now if we could unrestrict ours to get over 400 at the crank, we could get 300 + at the wheels! Then some simple mods to get even more.
