Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
brake lights on a 2004 dodge dully
Old Aug 17, 2007 | 11:18 PM
dino091266's Avatar
dino091266
Default brake lights on a 2004 dodge dully
A light came on the dash and saids there is a lamp out.The only lights that won't come on is the brakes. We changed the brake switch and that did not work. We changedthe bulb in the middle light on the cab of the truck. They still are not working and the other bulbs look good. Any Sugestions???????
Old Aug 17, 2007 | 11:28 PM
Drew's Avatar
Drew
Default RE: brake lights on a 2004 dodge dully
you may have to use some dielectric grease on the bulb you replaced. if that doesnt work you may have to go throughout your truck and physicaly check every bulb. the computer shoots a little voltage through each lamp to check for continuity. if nothing is returned it gives you that message, and it could all be just a weak connection.
Old Aug 19, 2007 | 02:03 AM
Parts/Service's Avatar
Parts/Service
A common problem on your truck is the tail light strip that the bulbs sit in. You will eventually haveto replace this. Isell alot of the strips because the lamp out light is on.
