Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
fuel question
Old Nov 3, 2007 | 08:33 PM
engineblock's Avatar
engineblock
Default fuel question
whats up everyone another question hope someone could help me.
i want to know how set the injector sync because my truck is running rich
Old Nov 8, 2007 | 10:53 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: fuel question
First, how do you know it's running rich? Is it throwing P0172 or 173? Have you looked and seen the ST & LT fuel trims way negative? Used a gas analyzer? Because unless the PCM or a spectrometer has told you this, it's probably not. About the only thing that'll make them run rich are failed O2's,or too much fuel pressure. Either way, it'll throw a code. CTS can effect it, but isonly used in OL.
Edit: Injector synchronization is done by the PCM with cam and crank inputs, and has nothing to do with fuel trims. And the Magnums batch fire, so it's not like you can time each injector seperately.
