Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
turn signal does not work when wipers are on
Old Nov 7, 2007 | 09:51 AM
rep329's Avatar
rep329
Default turn signal does not work when wipers are on
I have a 2004 ram 1500 the turn signal works when the wipers are on low but when the wipers are on high the turn signals don't work properly, also my wipers don't move to their fastest setting when this happens
Old Nov 7, 2007 | 05:35 PM
Deviantblis69's Avatar
Deviantblis69
Default RE: turn signal does not work when wipers are on
I seem to remeber a few post on here referancing an issue with the steering column pinching wires and causing problem. You might look into that if you use your tilt steering often.
Old Nov 8, 2007 | 07:12 PM
40intrepid's Avatar
40intrepid
Or you may have a bad multi-funcion switch.
This has happened to me and at least one other forum memeber.[:@]
