Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
fiberglass center console/speaker box
Old Nov 7, 2007 | 10:10 PM
ramfx4's Avatar
ramfx4
Default fiberglass center console/speaker box
hey i am thinking about building a center console with one sub faced toward the front window, in my single cab 2004 dodge ram. anybody have any ideas on a design or what would look good?????
thanks in advance
Old Nov 9, 2007 | 05:29 PM
tizzle0469's Avatar
tizzle0469
Default RE: fiberglass center console/speaker box
i built a fiberglass enclosure for my 04 awhile back. i crammed 2 memphis 12's in there...questions?
Old Nov 10, 2007 | 11:33 AM
ramfx4's Avatar
ramfx4
yeah, do you have a pic of it or a design
Old Nov 12, 2007 | 09:11 AM
tizzle0469's Avatar
tizzle0469
well no. it was stolen shortly after i finished it.lol....hate theives....anyway, i started by making two sides that curved over the center seat brackets ( so you can bolt it in )and that have the shape i wanted, it swooped down from the back window. you will need to rebuild the back wall before you start...its not hard just remove your plastic wall,remove the center seat belt by drilling out the rivits on the back ( if you ever want to put it back stock then you can just weld it back in! ) make a template of the curve in the back window and i just made it straight up and down.. then i just boxed in my sides with my proper cubic feet o' space. but the fiberglass part is simple.ijust needed to make a set of rings that fitmy sub(s) mounted them on my box and angled them away from each other, stretched spandex material over the top and brushed over my resin. lined the inside with glass and resin and sanded er smooth. i just wrapped mine in blue and black tweed. looked tight as hell...apparently too tight cause someone else wanted it....hope this helps
Old Nov 12, 2007 | 10:17 AM
ramfx4's Avatar
ramfx4
yeah it helps, thanks.....
Old Nov 12, 2007 | 10:40 AM
tdmopar59's Avatar
tdmopar59
ramfx4..... just a suggestion but you will prolly get a lot more and a lot faster feedback if you post under the third gen ram section......
