Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
2000 2500 brake issue
Old Apr 21, 2008 | 12:24 PM
schulzy190's Avatar
schulzy190
Default 2000 2500 brake issue
I have tried search and nothing seemed to be what this is....I have a 2000 2500 and just recently the brakes started acting up. the brake light on the dash as well as the abs are on. i can drive it fine but when its time to stop the pedal goes about 3/4 of the way before any braking or resistence starts. after that it brakes fine...i checked the fluid level and its fine...not sure whatelse to check...any thoughts let me know...thanks in advance
~Justin
Old Apr 21, 2008 | 02:20 PM
Drew's Avatar
Drew
Default RE: 2000 2500 brake issue
I bet you have a brake line that has swelled. . .would be easier to just change them all.
Old Apr 21, 2008 | 03:18 PM
schulzy190's Avatar
schulzy190
what would of caused it to swell? ive been around cars and trucks all my life never ran into a problem like this...but ill take a closer look at everything
Old Apr 21, 2008 | 05:13 PM
schulzy190's Avatar
schulzy190
I think i have found the cause to my problem there is a leak near the rear axle and it looks to be coming from the brake lines...i attached a pic...
[IMG]local://upfiles/88490/5FF38CF478D34D58B2A3A4C8D4E01C35.jpg[/IMG]
Old Apr 21, 2008 | 09:35 PM
Drew's Avatar
Drew
I'd say you found your culprit. . .
but to answer your question, sometimes those rubber hoses do give way. . .
Old Apr 22, 2008 | 12:45 PM
schulzy190's Avatar
schulzy190
is there anything i should know before i take it for a test drive? i have to bleed the lines but anything else?
