Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Ram 2500 or 3500
Old Jan 31, 2005 | 03:45 PM
jimwodke's Avatar
jimwodke
Default Ram 2500 or 3500
Does anyone out there know the actual difference between the 2500 and the 3500 other than more springs?
Old Jan 31, 2005 | 04:39 PM
Drew's Avatar
Drew
Default RE: Ram 2500 or 3500
other than being able to handle more of a load. . .nope
Old Jan 31, 2005 | 05:02 PM
Snafu's Avatar
Snafu
What year truck? The '94-'02 Ram 3500's were all dual rear wheel. The '03+ come dual or single. Another big mistake by Diamler.
Old Feb 2, 2005 | 06:01 AM
horatio102's Avatar
horatio102
3/4 tons usually have dana 60 rear axles and dana 44 fronts, diesels and 1 tons generally have dana 60 fronts and 70 rears iirc.
Old Feb 2, 2005 | 10:09 AM
Snafu's Avatar
Snafu
You're right about the rear axles, but most 3/4 tons did have the 60 front. Look at the GVWR, if it's 8800 pounds or higher then it's a Dana 60 front.
Old Feb 2, 2005 | 10:28 AM
DCXRJE's Avatar
DCXRJE
Progressive 2 stage rear spring on 2500, progressive 3 stage spring on 3500. Axles are the same up front, Dana 60s or Corporate comparable. Rear axles can be trickier. One ton single rear wheels and 2500s with High Outputs have the same rear axle. If you opted for the 2003 or short run 2004 2500 w/standard output Diesel you got the smaller rear axle. Obviously a dually has a different style front axle and a dually rear, it's a dually after all.
ORIGINAL: jimwodke
Old Feb 2, 2005 | 12:13 PM
Drew's Avatar
Drew
the axels on my 04 are AAM. I wish I had DANA axels, the ball joints on these AAM axels are junk[>:]
Old Feb 2, 2005 | 12:24 PM
Snafu's Avatar
Snafu
The ball joints on my front Dana 60 SUCKED too...
Oh yah, and my rear Dana 60 has a TON of extra backlash in the ring and pinion, it's making noise, and vibrates like hell on the freeway. I have to rebuild it soon. [:@]
Old Feb 2, 2005 | 01:10 PM
horatio102's Avatar
horatio102
Of course it depends on the year. My 86 has a gross weight of 8510, making it heavy duty and exempt from cats, but it has a D44 up front.
Not sure why Daimler switched to the AAM axles. Hopefully the aftermarket will get up to speed on them soon.
