Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Opinions wanted
Old Feb 9, 2005 | 07:03 PM
shortbus's Avatar
shortbus
Default Opinions wanted
OK, is it worth it.
I have the opportunity to buy an 85 power ram half ton 4x4 from a buddy. Its got a good running 318 and the 4 speed is in good shape. Its got a busted steering gear and broke pittman arm. Body is in ok shape. Would be a fun project truck. He wants $500 for it. How hard is it to find parts and whatnot. I'd like to do some minor engine work like a new intake manifold and carb, exhaust, sheet metal and suspension lift, probably 5". I dont want to dump a ton of money into it, it would just be a toy.
Old Feb 9, 2005 | 11:54 PM
horatio102's Avatar
horatio102
Default RE: Opinions wanted
I've got an 86 3/4 ton -
5-6" lift kit will run you about a grand, plus install if i remember right. Get springs for the back, not blocks.
steering gear will cost you about $200 for a remanufactured piece from Schuck's
drop pitman arm is about a hundred
spend the extra money and get the truck version carb - either the Truck Avenger if you like Holley or Edelbrock's equivalent. It's a major bugger to have the thing stall on hills. I've yet to find a paved road steep enough to get it to stall, but off-road you will.
I'd recommend Hooker Competition headers - 1 5/8" primary into a 2 1/2" collector (or similar sized from a different manufacturer)
Parts aren't too hard to come by, but sometimes you have to order stuff and wait a day or two from the local parts stores just because it's not a Chevy or Ford so they don't stock the stuff.
Old Feb 9, 2005 | 11:55 PM
horatio102's Avatar
horatio102
PS. If it's in decent shape mechanically except the steering stuff, jump on it at $500. I would.
Old Feb 10, 2005 | 12:25 PM
shortbus's Avatar
shortbus
yeah, mechanically, its in great shape. the only issues are the steering gear and the emergency brake gets stuck. other than that, the only problem is that its ugly. I dont mind ugly.
Old Feb 11, 2005 | 12:46 AM
magnethead's Avatar
magnethead
if the E-brake sticks, it just needs to be lubed (it should have rear drums i think?). Darn good deal for 500.
