Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Door Panels
Old Feb 12, 2005 | 05:55 PM
prerunner's Avatar
prerunner
Default Door Panels
How do they remove? I see one screw behind the door handle...and that is all. Is that all i have to remove?
And does anyone know what the colors are for the speaker wires? Which is positive and negative?
Thnx
Old Feb 13, 2005 | 04:19 AM
BlueHemi's Avatar
BlueHemi
Default RE: Door Panels
First remove the door latch handle by unscrewing the bolt underneath it. Next, there are 4 screws to remove: one at the very top front of the panel, one in the center by the door latch, and 2 on the very bootom of the panel. Once all those are removed, lift up on the panel and then slowly pull towards you until you can reach behind and unplug the power window/lock wiring (if you have them).
The basic audio system speaker wire colors (according to the wiring diagram) are:
left front (+) Light Green/Red stripe
(-) Light Green/Dark Green stripe
right front (+) Light Blue/Violet stripe
(-) Light Blue/Black stripe
left rear (+) White/Red stripe
(-) White/Black stripe
right rear (+) Tan/Violet stripe
(-) Tan/Black stripe
Old Feb 13, 2005 | 07:02 AM
prerunner's Avatar
prerunner
Thnx bro....but i had no patients.....so i already finished it. The dodge ram door panels are rather simple to get off
Old Feb 17, 2005 | 01:52 AM
Jdubbtx's Avatar
Jdubbtx
are you replacing speakers? If so you can just buy speaker adapters at Best Buy for a few dollars and that way you don't have to cut the plug so if you ever wanna put the originals back in you can just unplug the adapter.
Old Feb 17, 2005 | 01:53 AM
Jdubbtx's Avatar
Jdubbtx
