Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
will 15" rims fit on a 2000 dodge 1/2 ton? also lift questions...
Old Feb 8, 2004 | 02:18 PM
hpi_jeep's Avatar
hpi_jeep
Default will 15" rims fit on a 2000 dodge 1/2 ton? also lift questions...
im wanting to put some 15" wheels on my truck because i have a set of brand new 33's i had bought for my jeep but i never mounted them. my truck has 16" wheels on it right now.
also will 33x12.5" tires fit on the truck without lift? if not what is the cheapest 3" lift i can get? i would like to keep stock control arms, is there a 3" coil spacer available? i can just block the rear right? i would like to stay away from a body lift.
Old Feb 9, 2004 | 10:09 AM
Flex's Avatar
Flex
Default RE: will 15" rims fit on a 2000 dodge 1/2 ton? also lift questions...
the only thing you should check is if there is enough room for front brakes inside the 15" rims.
