Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Tranny problems ? i think
Old Oct 25, 2009 | 08:09 PM
ladodgerfan's Avatar
ladodgerfan
Default Tranny problems ? i think
I have a 1999 dodge ram 1500 it shifts fine in all gears, when its in drive about 20+ mph the rpm's are at 2,000 to 3,000 when i push on the pedal. It apears like a lack of power when it excelerates . I've already changed the fluids and filter there was only minute fragments in the pan and the color was a dark purple....it just whines at 25 so it cant upshift to drive anyfaster next step i believe would be to take the govenor valve out and see if i can clean it and inspect the vb...any help will be much appreciated to fix my truck cause its bin sitting for over a year now and im at my witts end about it. If im looking at the wrong end here let me know if its a sensor that is causing this instead of the tranny......would adding some translube by lucas work???
Old Oct 25, 2009 | 09:34 PM
MontanaRAM's Avatar
MontanaRAM
sounds like it's not shifting, probably a sensor went bad or your tranny is DONE, you might have blown the low end gears, happened to a work truck i was driving.
