Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
$100 REWARD
Old Apr 21, 2005 | 07:58 PM
Hyper1's Avatar
Hyper1
Default $100 REWARD
I have up a 100.00 reward for anyone who can fix my Dodge ram,
Here is the problem I ran into last week
I was leaving a gas station and the ABS light blinked on and then back off, I saw it do it again then it came on and stayed on.
I searched the web and forum but I have not found the problem yet. Here is what I have done so far!
1, Replace the rear ABS sensor (53.00) Did not fix problem
2, Checked all the vaccum lines and even took out the battery box
3, Checked all the fuses inside the truck and out side the truck.
4, Readjusted the Brake light switch, Crusie did not work before I did this, work good afterwards.
5, Checked the rear brake lights, all work including the 3 rd one.
6,took out lower knee boster, found abs computer and unpluded it, Light went out but came right back on when I pludded it back in.
7.Did the Key on Key off check, got a 12, and a 55, 12 is because of the next thing in the list
8. Disconnected the batteries over night, still the light comes on and stays on when key is on or truck is running.
9, unpluged the emergency brake switch, light still on
10, check for raw wires could not find any!!
11 Took to dealer today and let them hook up the scanner to it, tech said he could not connect to the abs , had no connection. They wanted to keep it and charge me out the tail so I brought it back home. I am at the Point where my 1996 Club Cab Dually is about to get traded in on another truck. I bought it new and it has 81,000 orginal southern miles on it. I am so sick I cant even think about this. I am offering 100 cash to anyone who can fix this truck. if it is the ABS module send me one and I will send you 100 if it works. If you tell me it is this wire or that wire and I check it and it fixes it, the money is yours! I have already loss money on this problem so I am willing to offer the $100 to the guy or girl who can tell me what is wrong with it. The only thing I see I havent check is the ABS module.
Old Apr 21, 2005 | 08:03 PM
jayskynr's Avatar
jayskynr
Default RE: $100 REWARD
what year ram is it ???? and all that other good info.
Old Apr 21, 2005 | 08:31 PM
Drew's Avatar
Drew
I'm willing to say the ABS computer is shot.
you said it yourself, the light went out when you unpluged it, but went right back on when you plugged it back in. if you have a friend with a similar truck swap modules. light goes out in yours but goes on in his theres your problem.
Old Apr 22, 2005 | 02:07 AM
RAMDAN1500's Avatar
RAMDAN1500
check to make sure you got any brake fluid.. if not then it could be your abs computer.. Never take your car to teh Stealership unless its going to be warrenty work. Find a good mechanic in your area and see if he has anything to say.
Old Apr 30, 2005 | 02:04 AM
EatnFordsShtnChevys's Avatar
EatnFordsShtnChevys
mine did the same thing, i went to the dealership and they told me my rear sensor was broke, they replaced it and the light went off.
Old Apr 30, 2005 | 12:15 PM
4DrMopar's Avatar
4DrMopar
Rear sensor or Proportioning valve (spongy pedla would accompany this)
Old Apr 30, 2005 | 06:51 PM
horatio102's Avatar
horatio102
Rear sensor was the first thing on his list guys, didn't help.
I'm going to put my money on it being the ABS module itself. Either the computer or the pump mechanism. If you can swap the computer, try it. If it's the whole ABS module that you'll have to swap and you don't want to deal with the hassle, perhaps it's time to trade it in.
