Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Dual Exhaust and Oxygen Sensors
Old Feb 27, 2004 | 11:38 AM
moonshine_1952's Avatar
moonshine_1952
Default Dual Exhaust and Oxygen Sensors
I'm going to be building a true dual exhaust system for my '96 ram. My design takes into consideration required amounts of backpressure, obstacles to the exhaust underneath the truck, etc, but I do not know what is going to have to be done with the oxygen sensors. What do I have to do to make sure my ECU is still getting the correct readings from my sensors with the dual exhaust?
Dan M.
Old Feb 27, 2004 | 04:02 PM
dodgeram56's Avatar
dodgeram56
Default RE: Dual Exhaust and Oxygen Sensors
I also want to put a dual exhaust on my truck can you tell me what i need to do or have the shop do i should say to get the correct amount of backpressure ect..
can you send me your plans
Old Mar 1, 2004 | 03:39 AM
goatslayerwp's Avatar
goatslayerwp
I believe I saw it in jegs, but dont hold me to that... its a little module that you plug into the rear O2 sensors and it fools them into thinking you still have a cat. If you throw you some magnaflows on there, you will still see much more flow over stock, but will have a little backpressure.
Old Mar 1, 2004 | 02:42 PM
bullitt1229's Avatar
bullitt1229
ORIGINAL: goatslayerwp
What you are referring to is called a mil (malfunction indicator lamp) eliminator. What it does is fool the computer into thinking that there are still cats on there. I needed them when I took out the stock h pipe on my mustang and put on an o/r x (no cats).
Old Mar 1, 2004 | 03:39 PM
dodgefreak's Avatar
dodgefreak
Hy, one of our new sponsors also sells them!! Give Dan a call at fastman performance!! Gonna be getting one myself soon!!!
Old Mar 1, 2004 | 03:51 PM
Vader's Avatar
Vader
Just be careful, Many areas are now hooking the exhaust up for a "sniff test" during the inspections. I don't know if they have annual inspections in your state but they do in NY.[:@] If the equipment does not detect cats, the vehicle fails inspection.
Old Mar 1, 2004 | 05:32 PM
dodgefreak's Avatar
dodgefreak
HE HE...no inspections in michigan!!! LOL ....for now at least!![8D]
