Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Switching to 180 deg thermostat...
Old Mar 4, 2004 | 11:15 AM
moonshine_1952's Avatar
moonshine_1952
Default Switching to 180 deg thermostat...
I know that switching to a cooler thermostat is supposed to increase power slightly, but in keeping the engine cooler, won't fuel economy decrease because more heat = better fuel atomization? Or am I completely off-base on this one?
Old Mar 4, 2004 | 01:33 PM
steve05ram360's Avatar
steve05ram360
Default RE: Switching to 180 deg thermostat...
I've never noticed a difference either way (fuel or performance) but I still do it anyway.
Old Mar 4, 2004 | 02:24 PM
dodgefreak's Avatar
dodgefreak
Its good and bad:
On the plus you will get a slight gain in performance (most noticable in the summer). Some other larger mods like a mopar PCM require the 180 due to the air fuel mix.
The down side is the mpg will go down a little, and if you dont have the performance PCM the cooler t-stat may cause your motor to run in wide open loop (think thats the term) causing you to run rich.
Old Mar 4, 2004 | 04:14 PM
steve05ram360
I've been told by a mechanic friend that the 180 t-stat will not send the pcm into open loop mode. I had just the 180 stat in my jeep GC 318 & it passed easily here in CA. He mentioned that if you went to the 160 it would stay in open loop.
Old Mar 4, 2004 | 05:13 PM
dodgefreak's Avatar
dodgefreak
It may be truck to truck. Guy on another site had the 180 and it kept him in open loop (99 Ram 5.2). When I first did mine I had no problems either
Old Mar 4, 2004 | 05:26 PM
steve05ram360
I wonder if there might have been something else going on w/his truck. Or maybe they changed the stock programming (my jeep was a 93).
Did he mention how he knew it was in open loop? CE Light?
