Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
360 Oil Consumption
Old Jun 8, 2005 | 03:23 PM
SoxFan33's Avatar
SoxFan33
Default 360 Oil Consumption
Posted in Van and Ram sections since it is an engine specific question.
I have searched the forum and found quite a few posts concerning low oil pressure but none about oil consumption so here is my problem and a few questions.
I have a 1996 3500 Van (camper) at 40K miles with a 360. The engine runs fine but consumes a quart of oil about every 600 miles. There is no obvious leaks (and at a quart every 600 miles it should be obvious). This leads me to believe it is being burned. There is no obvious odor or smoke (exhaust or other). I have been given a few suggestions from co-workers (non-mechanics) that I should change the PCV and look at the intake manafold gasket (obviouls change if I remove the manifold). Is this reasonable? What else should I be looking at?
Thanks,
Bob
Old Jun 8, 2005 | 08:05 PM
osteodoc08's Avatar
osteodoc08
Default RE: 360 Oil Consumption
Do a search for plenum gasket leak and you should find a wealth of information as to where your oil is going. Seems to be a common problem and a relatively easy fix if you are mechanically inclined, however, it may be a little more difficult to access it on your van. Hope this helps.
Old Jun 12, 2005 | 03:53 AM
wpbmed's Avatar
wpbmed
It's your plenum gasket. Buy an aftermarket one off the internet, or buy an M1 intake and be done with it. The plenums leak ALL THE TIME! Very **** poor and stupid design by Dodge
