Ram heater core leak...help!!!
I have a 1500 Ram with a heater core leak. The heater core is covered under warranty, but there is a second problem to this. The coolant vapors are stuck to the inside of all the glass, making it almost impossible to see unless you wipe off the glass every couple of minutes. I have tried about everything I can think of to clean the glass (windex and variants, rubbing alcohol, acetone, goof off, lemon cleaners). What will get it off the glass? I even tried scraping it with a razor blade. The vapor is not just there when the engine is running...it is there ALL the time. I forgot that I even tried to steam it off.
If I cannot get it clean myself, I need to either have Dodge figure out how to clean it or have them replace the windshield.
Any ideas?
-SquirrelNuts
Any ideas?
-SquirrelNuts
