Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Replacing stereo
Old Mar 9, 2004 | 01:56 AM
Vader's Avatar
Vader
Default RE: Replacing stereo
AudioBeast, The steering wheel controls will not work with the aftermarket deck
ORIGINAL: audiobeast
My only question is can you still use your steering wheel controls when you replace the deck?
Old Mar 9, 2004 | 01:57 AM
Vader's Avatar
Vader
Got my Adapter from Best Buy 12.99.
ORIGINAL: gpzjack
I just installed a new alpine xm unit in my 04. Its sweet because the xm tuner is built in all i have to do is install the antenna. Speaking of that where can i get the antenna adapter. I hooked my system up and i need one. You guys are right it was a piece of cake took about 10 minutes with the harness already wired up.
Thanks
Old Mar 9, 2004 | 09:09 AM
mississippi's Avatar
mississippi
No mods need to be made. Direct fit and hook up.
ORIGINAL: bullitt1229
I had a question. Will the factory radio with AM/FM/CD/Cassette replace the existing radio with just the AM/FM/CD? Or will some modifications need to be made?
Old Mar 9, 2004 | 03:10 PM
Klute's Avatar
Klute
Great the new head unti should be a breeze!
Anything on how to remove the door panels?
Old Mar 9, 2004 | 08:09 PM
bearcat74's Avatar
bearcat74
Pretty easy also, Replaced the speakes with Infinity 2 ways. The window crank has a clip in the back you push off. Remove the screw from the door handle. After removing the screws lift up and off it goes. If you have power windows the clips are easy. The rear panels are a little more on the difficult side. I will send photos of that one this weekend. Over all its not to hard of a job.
