Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
windows stuck down, odometer doesn't move
Old Jul 8, 2005 | 03:48 PM
TWO2500S's Avatar
TWO2500S
Default windows stuck down, odometer doesn't move
Here's one for you guys,
Yesterday after filling up with fuel, I started my '02 2500 Cummins up and the horn honked once, the abs light stayed on, the air bag light stayed on, the windows won't roll up, the odometer doesn't move, and the keyless entry doesnt work. I took it home and turned it off and back on and it did the exact same thing...and it did it every time I tried it last night. Everything else works fine...wipers, AC, radio, tach, gauges etc. Anyone have any suggestions on what to look at as the culprit? I've looked at a few things but had no luck. Any help is greatly appreciated...
Old Jul 9, 2005 | 02:48 AM
horatio102's Avatar
horatio102
Default RE: windows stuck down, odometer doesn't move
have you tried disconnecting the battery and letting it sit for a few, then reconnecting it? Sounds like the electrical system needs a good reset.
Old Jul 11, 2005 | 01:11 PM
TWO2500S's Avatar
TWO2500S
Yeah, I thought disconnecting the batteries may work as well...but no such luck...I pulled the cables from both batteries...cleaned the terminals and let it sit overnight...but unfortunately it didn't cure it.
Old Jul 11, 2005 | 08:35 PM
TWO2500S's Avatar
TWO2500S
Found the problem...had a main fuse blown in the ignition fuse box....everything is working just fine now...not sure what caused it...but thanks for the help.
Old Jul 12, 2005 | 01:18 AM
horatio102's Avatar
horatio102
Whoa. Weird. You can drive with no main fuse? Wow.
