Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
vibrating noise in door
Old Mar 14, 2004 | 04:57 AM
sparky's Avatar
sparky
Default vibrating noise in door
In my Ram I have the 7 speaker infinity system. I listen to mostly rock music and anytime the bass hits my door vibrates and makes an annoying buzzing noise. Does anybody have this problem or know how to remedy this? it is driving me nuts!
Thanks for the help.
Old Mar 14, 2004 | 05:47 AM
dodgeram56's Avatar
dodgeram56
Default RE: vibrating noise in door
i have a 98 ram and i have the same problem i dont know what sound system came in that year but it pisses me off
the only solution i can think of would be to dynomat the doors
Old Mar 14, 2004 | 11:48 AM
Mouthdog75's Avatar
Mouthdog75
The passenger-side door on my '95 makes a vibrating noise. I assumed it was caused by a compromised speaker cone - perhaps it is something else. Today I'm going to remove the door panel to take a look. I'll get back to you.
Old Mar 14, 2004 | 08:20 PM
356MAGNUM's Avatar
356MAGNUM
Same here for the rattles. It's mostly the plastic vibing on the door where it meets. Also the most annoying sound is the tire gauge that I forgot that I put in the rear map pocket(hah). Dyno mat will help for where the clips meet the metal, but the edges is a different story. I have found on stereo installs that if you take the 1/2" weather stripping and outline of the bottom of the door that it helps the most. You are stuck with seeing a lil bit of strip but on the bottom its not all that noticible unless you go for the competations and have judges.
[IMG]local://upfiles/2144/Yw670964033.jpg[/IMG]
Old Mar 18, 2004 | 02:06 AM
vagabond's Avatar
vagabond
There is a technical service bulletin for the vibrating noise in the door. Talk to your dealer. Its a simple fix.
TSB Number Issue Date TSB Title
08-16-00 APR 00 Entertainment Device - Front Door Speaker Buzz
