Super Charger Good or Bad
Greetings,
What are the Pros & Cons of Super Chargers? I know they boost up your Horses but I don't know by how much. Are they dangerous for your engine?
I know they void the warranty.
Can a Super Charger be used with a programer or chip?
thx
thx
The supercharger is tougher on the engine. The pressure is greater, causing higher pressure on bearings, valve springs, etc. The supercharger also has a lot of parasitic lose to operate. If you get a kit from Kenne Bell, they will give you a controller that works with the kit. The kits are pretty complete from what I've heard.
this site has lots of good info http://www.kennebell.net/faq/faq1.htm
yawnshemi420: this page seems to address your question
http://www.kennebell.net/faq/faq-answers3(2).htm
If you're still wondering about power, most Twin Screw Superchargers boost your power by about 50% of the engine's power. If you've got 345HP and add the Twin Screw Supercharger it'll be at or near 520HP. I believe the Kenne Bell for the HEMI brings it to 517HP.
One thing I'm not sure about is this:
If I've got the HEMI and I add the Supercharger with a 50% boost, that would put it at or near 520HP. If I mod it to 425HP, then add the Supercharger, would it add 50% of the stock power or the modded power?
