Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Stereo Installation Directions for 02 and Up Rams
Old Mar 17, 2004 | 09:13 PM
bearcat74's Avatar
bearcat74
Default Stereo Installation Directions for 02 and Up Rams
For anyone needing directions for installing new components in your '02 and up I have the directions in pdf. Leave a post or email me and I will send them to you.
bearcat74@sbcglobal.net
Old Mar 30, 2004 | 01:40 AM
curt7035's Avatar
curt7035
Default RE: Stereo Installation Directions for 02 and Up Rams
Hi,
Do your directions include radio harness codes for an 04 Ram Hemi with an infinity system?
Old Mar 30, 2004 | 01:50 AM
bearcat74's Avatar
bearcat74
Curt,
Here is the part number for the adapter that I used: Scosche CR02. I have a list of parts that I have used but can not locate the file right now. This should work for your purposes. Make sure to get an adapter for the antenna also: Scosche CRA
The adapter should work for your 04 also. The trucks are all wire the same whether you have the Infinity system or not.
Old Mar 30, 2004 | 02:53 AM
curt7035's Avatar
curt7035
Thanks Bearcat,
I'm having problems installing a MTX amp and Rockford sub system with the oem infinity. The amp is supposed to have a "smart engage" feature, but it doesn't work with dodge radios, apparently. I don't have a dmm yet, so I need the wiring diagram to determine the switched ignition lead to wire to the remote terminal of the amp. I am using a line level converter. If you could e-mail the pdf file to curt7035@yahoo.com, I would appreciate it. Thanks again.
