Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Winshield Washer Spray Nozzles
Old Mar 18, 2004 | 10:57 PM
Mouthdog75's Avatar
Mouthdog75
Default Winshield Washer Spray Nozzles
The winshield washer spray nozzles on my '95 1500 put-out like an old man at the urinal! Does anyone know what causes this and how to fix it?
Old Mar 18, 2004 | 11:19 PM
Ratchet's Avatar
Ratchet
Default RE: Winshield Washer Spray Nozzles
Could be a number of things. A worn out washer pump, clogged nozzles, a cracked washer line, or maybe even a kink in the line. Can you hear the pump running when you push the washer button?
Old Mar 18, 2004 | 11:22 PM
moparturd's Avatar
moparturd
They get a build-up from the fluid going through them. You can replace them, with parts from the dealer, usually just a couple bucks each, or take them off and get a straight pin and see if you can break loose the build-up. Make sure that your pump is in good shape and the filter in the washer tank isn't clogged as well. Good luck.
Old Mar 19, 2004 | 01:20 AM
Aftrshck's Avatar
Aftrshck
these guys hit it pretty well....i have always ended up replacing the pump....not the gunk thang.....the pumps are pretty easy to fix....
Old Mar 19, 2004 | 01:38 AM
Vader's Avatar
Vader
Quite desciptive. I'm with the others. Pump or deposites in lines.
ORIGINAL: Mouthdog75
Old Mar 19, 2004 | 01:41 AM
Aftrshck's Avatar
Aftrshck
i was laughin about that description too....worst part...the visual was just freakin disturbing....LMNO!!
