Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Shifting Problems
Old Mar 19, 2004 | 11:28 PM
CaliHemi's Avatar
CaliHemi
Default Shifting Problems
Alright. I purchased my 04 QC 4x4 hemi in the last part of December. I've noticed about 2 weeks after I got the truck that the shifter sticks on occassion. When I go to pull it towards me and down it locks up. I have to push it forward again and pull it back down for it to unstick. It doesn't do it all the time but it is annoying. MY actual concern is that recently, 2 times the last 2 weeks, when I hop into the truck, turn it on, put it into reverse and step on the gas a little the engine revs up like it's in neutral. ????????. I check it again and the dash light is on the R. I have to put it back into park and then shift it to reverse for it to work. Is anyone else having this problem? Do any of you notice the hard shifting when going from park to reverse and drive? It makes a clunking sound. Should I be concerned?
Old Mar 20, 2004 | 01:25 AM
BigDave's Avatar
BigDave
Default RE: Shifting Problems
I can't answer much of your question, but I heard someone else mention this clunking sound. I check for that this morning, and yes I heard it too, but I noticed the truck lurch when this happened. So I repeated the process with my foot on the brake a little firmer, and there was no clunk. Let up a little bit on the brake a bit and tried it again: clunk. Try it, I was suprised the solution was so simple. If you are still clunking after this test, then I wasn't any help at all. [:@]
Old Mar 20, 2004 | 01:46 AM
Vader's Avatar
Vader
I have noticed this to on my Truck. It seems to happen if I do not depress the brake all the way when I go to shift. I think it may have something to do with the brake unlocking the shift mechanism. It is a pain sometimes.
