Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Need info on 4.10 axle ratio
Old Mar 25, 2004 | 05:34 PM
DrewCat's Avatar
DrewCat
Default Need info on 4.10 axle ratio
Im looking at a new Ram 2500 but it has a 4.10 instead of the 3.92 axle ratio.
Can anyone give me info on the 4.10 vs 3.92
Thanks
Old Mar 25, 2004 | 06:02 PM
moparturd's Avatar
moparturd
Default RE: Need info on 4.10 axle ratio
What do you need to know?[sm=smiley24.gif]
Old Mar 25, 2004 | 06:34 PM
DrewCat's Avatar
DrewCat
I need to know what is better?
Whats better about a 3.92 and whats better about a 4.10
Thanks
Old Mar 25, 2004 | 07:13 PM
dodgefreak's Avatar
dodgefreak
They will buth give you much better low end grunt but the 4.10s will give more than the 3.92s. But at higher speeds the 4.10 will make you rev higher than the 3.92s
4.10s will let you pull more from a stop and at surface streets.
3.92s will let you pull better at high way speeds.
Old Mar 25, 2004 | 07:37 PM
Tempsho's Avatar
Tempsho
If your planning on running bigger tires, the 4.10 is the way to go.
Old Mar 25, 2004 | 07:43 PM
DakaDan's Avatar
DakaDan
How can a person fiqure out which axle ratio they have? @ 60mph I am reving around 2k. But I'll check today on the way home to make sure.
DakaDan
Old Mar 25, 2004 | 08:17 PM
dodgefreak's Avatar
dodgefreak
should have a sticker in the hood, radiator support, or doof frame.
Mine is on the hood.
Old Mar 25, 2004 | 08:46 PM
Vader's Avatar
Vader
My ratio is on the rear axel on drivers side.
Old Mar 26, 2004 | 12:03 AM
CaliHemi's Avatar
CaliHemi
Speaking of getting bigger tires...will the 3.92 run 35's okay? I really dont wanna spend the money to get big tires if the things gonna be slow.
