Amplifier for subs in pro box.
Hello,
I have a 2005 Dodge Ram 1500 Quad Cab. I have just purchased a pro box to go under the rear seat and two 10" Earthquake Shallow Wall Subs to go in it. Does anyone else have this set up. Anyone have suggestions of what kind of amplifier i need. How does this setup sound. Thanks for all the help folks.
Chris
Chris
Your speakers should have a wattage requirement on them. Once you know what that is....it should help you determine what kind of amp you should get. Any Rockford Fosgate amp would be ideal.....between 600-1000w should be more then plenty.
fourtwenty: How big an amp will fit in the middle? Did you change out your headunit too? I ended up getting the GPS deck so unfortunately I cant change it out but I want to start checking on options.
I had the same set up at one time. The best amp would be a audiobahn A12001DT
http://www.audiobahn.com/frame2004.html view pic
