Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
blinking dome/map lights
Old Oct 22, 2003 | 03:25 AM
simoneyez's Avatar
simoneyez
Default blinking dome/map lights
Lately the dome and map lights on my 02 Ram blink off and on randomly. Anyone have the same experience. Cause?</P>
Thanks</P>
Old Oct 26, 2003 | 07:57 PM
QuadRam03's Avatar
QuadRam03
<FONT face="Arial, Helvetica, sans-serif">I have a similar problem, I just brought a 03 quad 1500 and every now and then not only does the inside lights go on and off but so does my headlights andthe lights on the dash. I have taken to the dealer but they cannot find a problem. Anyone else seen this problem ? </FONT>
Old Oct 27, 2003 | 02:10 AM
dodgefreak's Avatar
dodgefreak
my 87 New yorker used to do that when ever I would make a left turn....lol...dont mis that car at all!
Old Oct 27, 2003 | 11:09 AM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Have you checked to make sure your relay's are all well connected and the wires aren't lose behind the switch?
I'll consult some of the mechanics at the dealership to see if they recommend anything. Do you, QuadRam, know what the dealer checked on?
~Amanda
Old Oct 29, 2003 | 05:22 AM
DODGE Germany's Avatar
DODGE Germany
</P>
There must be little problem with big results in your headlights switch unit.As I know,you can activate the dome lights in the ´03 model, too. isn´t it?If so, there maybe two problems: 1. The complete unit isn´t ok, because there is a shortcut in the platines. I bet they didn´t checked it inside and (Murphy´s Law) they hadn´t any problems during their search.2. Remove the switching section yourself and check every single cable on scratches in the insolation.They´re really packed together, so the chance of sticking together and rub each other is great. A problem after thisthree cable-strings (Headlights/domelights/dashlights)is uncommon, cause their´re splitting in different ways.The only hot spot in this case is the switching unit or the next 15"along the cable-string. Greetings, DODGE Germany, Michael</P>
Let me know,please, if I´m right.</P>
Old Nov 1, 2003 | 03:01 AM
simoneyez's Avatar
simoneyez
Thanks to all who replied. The problem went away... at least for now. If itreturns and I do something about it, I'll let you all know the results.
Old Nov 1, 2003 | 12:17 PM
dodgefreak's Avatar
dodgefreak
now that realy makes me think something is loose or shorting out!
