Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
1986 ram 1 ton
Old Oct 22, 2003 | 06:29 PM
sealcoat's Avatar
sealcoat
Default 1986 ram 1 ton
i would like to get some more torque or power out of my 360 cu inch 2 wd auto dodgr ram (350) it has 44,000 orig miles i have a sealcoat tank on it with flat bed also it has a eletric dump under it so it does have a load on it what type of parts would i need to crisp up the power without getting crazy?? i get around 9 miles per is that ok ?? thanks
Old Oct 22, 2003 | 06:34 PM
dodgefreak's Avatar
dodgefreak
well, when you upgrade the first thing you wanna do is get it breathing better! start out with a less restictive intake, performance exhaust, performance TB, or carb(is it carb or TB??) then headers. after that you can start heading into the motor.....RR's...cams...tintake manafold stiff like that. but with the weight you have, be care full with the intake manafold...alot will cost you low end (thats where the RR's come in
