Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Anyone used bigger injectors?
Old Apr 3, 2004 | 01:25 AM
chfjim's Avatar
chfjim
Default Anyone used bigger injectors?
Im looking into getting some bigger injectors for my ram, has anyone ever used them or know were to get them? since Im in there working anyway I thought maybe I can get some 21lb injectors instead of the 19lb stock?[8D]
Old Apr 3, 2004 | 02:23 AM
chfjim's Avatar
chfjim
Default RE: Anyone used bigger injectors?
check these out!
http://www.hughesengines.com/general.../injectors.asp
Old Apr 3, 2004 | 04:54 AM
bearcat74's Avatar
bearcat74
Chfjim,
Yes you can go with larger injectors and get some good gains. I have huge selection in the garage and luckily they fit the Ram. I had done some testing with my camaro and guess what they fit. I am currently running a set of 25lbsh. Not bad on the performance but he PCM flash can accomidate the extra fuel. It does show in mileage, rather largely, so I will most likely go back to the Bosch22's that seem to be in the ballpark of where my 4.7 likes to be... Fuel injectors have become very like in design and fit over the last few years. So go online and see what kind of deal you can get. I have never paid as much as the sight that you pointed out.
Bearcat
Old Apr 3, 2004 | 06:53 PM
chfjim's Avatar
chfjim
Bearcat Thanks, I think if anything Id only go up a small bit like to the 21lb injectors. I have a comp prog so I can flash it! Thanks[sm=smiley20.gif]
Old Apr 3, 2004 | 08:35 PM
Monrozombi's Avatar
Monrozombi
what exactly do these injectors do and how expensive and easy are they to install?
