Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Gear Guru's Step inside
Old Apr 3, 2004 | 03:06 AM
Vader's Avatar
Vader
Default Gear Guru's Step inside
I was told my 3.55's will have trouble turning the 315's I covet. Is this true. Don't want to hurt my baby.
Old Apr 3, 2004 | 04:47 AM
bearcat74's Avatar
bearcat74
Default RE: Gear Guru's Step inside
315 what Vadar. I can give you an answer if I have a bit more info...So let me know.
Old Apr 3, 2004 | 02:26 PM
Vader's Avatar
Vader
Sorry. I want to put 315 70 17 which has a diameter of 34.8 inches. I currently have 265 70 17 which is about 31.6 inches in diameter. I had the torsion bars adjusted to accomidate the height but now I am concerned the 3.55 gears will have trouble spinning them. Do I need 3.92 or 4.10.
Old Apr 3, 2004 | 03:11 PM
bearcat74's Avatar
bearcat74
Your not looking at to much of a difference in height so you may loose a little on the bottom end. The truck will handle them very well. One of those rearends would help, but really not nessasary. I am still looking for the calculator program for suggested gearing for tire size. I will post it as soon as I find it.
Old Apr 3, 2004 | 04:51 PM
Vader's Avatar
Vader
Thanks. I do mostly city driving and very rarely get on the throttle. Gas is expensive these days[:@]
Old Apr 14, 2004 | 02:45 AM
356MAGNUM's Avatar
356MAGNUM
one formula i have is (new tire size/old tire size)*ratio
(35/31)*3.55
