Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
87 Octane vs. 89 octane?
Old Apr 4, 2004 | 12:02 AM
excelent3's Avatar
excelent3
Default 87 Octane vs. 89 octane?
Is anyone burning a good quality 87 octane in their 5.7 Hemi?
I read the owners manual and they recommend mid-range, but also worded it in a way that 87 octane could be run also. I am in the break in period with less than 500 miles on the truck. Just wondering if a good quality 87 octane ( Mobil, Amoco, Shell) would be suitable after breakin. Wonder if gas mileage would be any different also.....
Thanks in advance.......EX3
Old Apr 4, 2004 | 12:06 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: 87 Octane vs. 89 octane?
Octane is just an anti-knock rating. It has nothing to do with your mileage or power. It is one of the most misunderstood things in the automotive world (read that as a plot by the oil companies to get us to spend more for gas...)[sm=smiley36.gif][sm=smiley36.gif]
Old Apr 4, 2004 | 12:22 AM
excelent3's Avatar
excelent3
So what's your advice regarding my question?
Old Apr 4, 2004 | 12:47 AM
Ratchet's Avatar
Ratchet
dustyloins is absolutely right. Basically, run the lowest octane you can as long as your engine doesn't knock/ping. Try running 87... if you don't have any problems, stick with it. If you do develop the knocking, add some octane boost and switch to a higher grade fuel in the next tank.
Old Apr 4, 2004 | 12:53 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
...thanks for the "backup", Ratchet...[sm=smiley20.gif]
Old Apr 4, 2004 | 01:16 AM
JzJonathan's Avatar
JzJonathan
This can offer some explanation.
http://www.caranddriver.com/article....rticle_id=3604
Old Apr 4, 2004 | 01:38 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Good article!! Thanks. As I've stated before in other threads, I worked at Southwest Research here in San Antonio, Texas as a Test Car Driver for several years...the results you refer to are "in line" with what our findings were.
Before I left Southwest Research, I asked a tech rep/mechanic what was the best thing I could do for my car/truck to keep it running like new. He said, "Change the oil often with a synthetic brand (he didn't specify), and run unleaded regular with a bottle of "Techron" every 6 months or so"....that's it....simple , easy, cheap. And our cars regularly ran well past 150,000 miles...[sm=smiley4.gif]
Old Apr 4, 2004 | 07:56 PM
RcBandit28's Avatar
RcBandit28
I started running 87 in my HEMI when I first got it...caused a Spark Knock....switched to 89..no more spark knock...owners manual recomends 89.
Old Apr 4, 2004 | 08:18 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
One thing good about the SRT-4, it tells you right on the gauges what type of fuel to use...no problems, no questions!!![sm=smiley20.gif][sm=smiley4.gif]
Old Apr 5, 2004 | 04:35 AM
excelent3's Avatar
excelent3
Thanks to all for the input, I'll give the 87 octane (Mobil, AMoco, etc) a try once I get past 500 miles or so, which apparently is the breakin designation....
