Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
New here! Problems with a 1997 Ram Laramie 5.2L
Old Sep 12, 2014 | 11:00 PM
Swifty13Swift's Avatar
Swifty13Swift
Default New here! Problems with a 1997 Ram Laramie 5.2L
Hello,
This is my first post on this site, and I'm hoping someone can help! I recently purchased my sister's 1997 Ram 1500 Laramie, 2WD, 5.2L extended cab. Now, this is my first Dodge, and he's been having some issues...
The truck starts up great. While the engine temperature gauge is below half, the trucks sounds incredible, drives great, etc. Now, when the temperature gauge is a little over half (Normal operating temp.), and you come up to a stop light, the RPM of the engine changes. It will drop down to about 500 RPM, then bounce right back up, all in a matter of half a second! It never stalls out, and it happens maybe... Three times in a two mile drive (from start to stop). When I shut the A/C off, it seems like the idle issue doesn't happen. I am assuming this has to do with the load being applied.
At any rate, I have done plugs (Copper Autolite 5224, gapped to .040), fresh oil, resealed the differential, air filter, had someone clean the IAC (I don't know if he re-positioned the plunger), had the cats, fuel trim and O2 sensors checked at work on a Genysis scan tool, replaced the battery, checked the alternator (pushing 92 peak amps, which seems low to me?), cleaned out the ground wires that had a little corrosion in them, had the fuel pump and CPS replaced. I cleaned out the throttle body. I also checked the intake plenum for leaks by spraying carb cleaner on it, and the idle stayed even.
The vehicle shifts fine, doesn't make any weird noises, has no check engine light on, and seems great until it hits that area in the temp. gauge that is slightly over half (To clarify, if cold is 0%, the middle line is 50%, and hot is 100%, the area where it acts up, and where my "normal" temp is would be 55%).
I am completely out of ideas, and any would help. I greatly appreciate it, and thanks for having me on this forum!
