Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
97 5.9L dodge ram a/c
Old Jan 29, 2015 | 03:28 PM
Brian'stime's Avatar
Brian'stime
Default 97 5.9L dodge ram
I am mechanically minded but older!! Is the water pump a job that's a major pain or a easy project knowing I have the tools to do it for the first time?? Any first timers who wish they didn't or found it o/k??
Thanks
Brian
Old Jan 29, 2015 | 03:59 PM
Your title says a/c but your asking about a water pump....which is it?
Old Jan 29, 2015 | 04:06 PM
Brian'stime
Changed to with a/c...better:-)
Old Jan 29, 2015 | 08:37 PM
Read what you just wrote. That made no sense. At any rate, water pump is not hard. Plenty of videos on you tube.
Old Jan 29, 2015 | 09:04 PM
Brian'stime
Default 97 5.9l
Mr Keaton; it seems that I'm being graded by my high school language arts teacher. I asked a pretty simple question, I've seen three you-tubes, and all were different, hence my question. I joined this site for valued info from experts and or experiments. Sooo have YOU actually replaced the water pump before and can answer that part??
Old Jan 30, 2015 | 08:17 AM
Yes I have replaced many water pumps. It is not that hard of a job and can be done with basic hand tools. Disconnect the battery, remove the fan shroud, remove the cooling fan, drain the cooling system, remove the serpentine belt, remove the hoses, remove the water pump. Installation is reverse of removal. Bleed the system when done to ensure no air is in the system.
Still don't know what your air conditioner has to do with any of this though. Can you not see the confusion in that just might be generated by your thread title and your actual question? I can't read your mind. I can only address what you write and if I can't understand what you write you will probably be dissapointed in the responses you get.
