Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
2" leveling kit *pics & write-up*
Old Apr 8, 2004 | 07:19 PM
Tempsho's Avatar
Tempsho
Default 2" leveling kit *pics & write-up*
This is a step-by-step write up of how to install the Skyjacker D20 2" leveling coils and Skyjacker Hydro shocks on a 1994-2001 1500 Ram 4x4. These steps are compiled from my memory, so I might have forgoten a step or two. Either way, I take no responsibilty for any modifications or upgrades you do to your own truck. Even though this is a pretty easy install, I still would like to post it. Most of you have at least done this or more, so bear with me, im new, and just starting out.
Pre Step: Soak every nut and bolt you are going to remove with penetratin oil!! Let soak for a good 20 minutes, then resoak each bolt right before your about to remove them.
1. Undo sway bar end links.
2. Remove nut on the top of each shock and remove upper shock mounts.
3. Remove lower shock bolts and pull old shocks straight up.
4. Jack up one side of the truck until old coil can be pulled out (make sure e-braKe is on)
5. Clean coil pad with a wire brush (there will be alot of crap on this base if you havent cleaned it for a while, or at all)
6. Install new 2" leveling coil in the factory location.
7. Lower truck down very slowly, making sure coil is lined up right.
8. Install new shock (or old shock, factory shocks will work with a 0"-2" lift)
9. Tighten lower shock bolt, install upper shock mount
10. Making sure shock bushing is centered, tighten the upper shock nut.
11. Double check lower and upper shock bolts and nuts to make sure they are tight.
12. Now repeat steps 1-11 for the other side
13. Now that the truck is lifted 2", you can re-attach the sway bar ends.
14. And your done.
Besides the fact that the bolts are really tough to get at, and are probably pretty rusted, the rear shocks are pretty much the easiest thing to replace on your truck. I replaced mine at the same time with SJ Hydro shocks. I really dont think this needs a write up.
I know with my truck before I installed the 2" leveling kit, it bottomed out very easily on big dips in the road. Now, it doesnt bottom out at all. Very well worth the $200 investment.
I also installed the Skyjacker daul shock steering stabalizer kit. For some reason, the passenger side bracket didnt want to mount in such a way where the shock wouldnt rub on the track bar. Sooooo, I installed it upside down. This way, it still clears, and does what it supposed to do. It must be a 1500 thing because the 2500's suspension is a bit different.
Anybody else with a 1500 have this problem with this kit?
At the same time, I replaced the old worn out door trim seal, and replaced the drivers side Sport headlight a$$embly. The old light was all dull and tarnished on the inside.
BEFORE AND AFTER:
Everything took me about 8 hours to do. I worked by myself for most of it.
And here is the final product.
Whew, and I'm finally done. You may now post away and let me know what you think.
Old Apr 8, 2004 | 07:33 PM
Vader's Avatar
Vader
Default RE: 2" leveling kit *pics & write-up*
Let me be the first to tell you.
Your Truck looks F*****G Awesome. Great job.
Old Apr 9, 2004 | 12:54 AM
gcredneck02's Avatar
gcredneck02
SWEET ride. What is the link to your site on cardomain?
Old Apr 9, 2004 | 01:18 AM
chfjim's Avatar
chfjim
Swwwwweeeeeeeeeeeettttttt! Awesome Job!
Old Apr 9, 2004 | 01:50 AM
DK08's Avatar
DK08
Thats a nice ride, I love the bug gaurd!!!
DK08
Old Apr 9, 2004 | 03:00 AM
Redhawk996's Avatar
Redhawk996
Looking good!
Old Apr 10, 2004 | 06:30 AM
Tempsho's Avatar
Tempsho
ORIGINAL: gcredneck02
Here it is. http://www.cardomain.com/memberpage/259005/9
Thanks for the replies guys
Old Apr 10, 2004 | 11:53 PM
Ruslt's Avatar
Ruslt
Looks Great! Great Job!
Old Apr 11, 2004 | 12:46 AM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Can I post this in the coming soon Tech Section?? You get credit and everything.. LMK!
~Amanda
Old Apr 11, 2004 | 12:50 AM
Tempsho's Avatar
Tempsho
Yes, most definatly you can use it in the tech section. If you need anything else, just ask. (what is lmk?)
