spinnig tires
I've got a 04 1500 reg cab 2wd 4.7 5sp auto 3.55 rear with about 700 mi. on the odometer. Last night I tried to spin the rear tires and it won't do it.
I don't want to power brake it or beat it, but I thought for sure it would have enough guts to turn a tire.
Is this programming or something that will chang when the truck is broken
in? I love the truck any way just wondered if something is wrong with my truck.
I think vader means I wouldn't be to concerned.
3.55 is low and my guess is its a locking differential?
Automatic overdrive so you'd have to put it into a lower gear, and just try it with the brakes on.
I have the same problem If I try 3 or four times it will break loose. I only had 800 miles the last time I tried and now have about 1800 so I might try it again. Gas and tires are to expensive to be doing it very much.
