Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
dodge ram 250 fuel problem
Old Apr 13, 2004 | 11:11 PM
JustinPeel's Avatar
JustinPeel
Default dodge ram 250 fuel problem
Hello once again, i hope that life is treating you all well.
First is that every once in awhile, my van stops getting fuel from the fuel pump.
This has been an ongoing problem, it is a 1992 250 ram, (an old telephone repair truck)
I replaced the fuel pump.. worked for awhile
replaced the filter too... sigh
When that wasnt the solution, had the relay replaced... worked for awhile
then it seemed to be wiring, whenever i crawled underneath it, and jiggled it around where the harness connects, it would work again. then I noticed that the harness coupler was in bad shape, so i cut the wires and wired them directly [IMG]
that also worked for awhile...
then it died on me a couple of times, always the same thing, no fuel from the pump, and if i let it sit for hours, or even overnight, it would start again.
It has two lines, and i cut the hose and put fresh clamps around them.
Now is sits in a driveway, and refuses to cooperate.
Please..
Where can i find a complete list of things to check for this problem. from fuses to fuel pump. it would help if they also told me how to check it....
p.s. (am i asking too much for diagrams.??? lol)
Thank you very much for your time and effort...
Glenn Beacj
