Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
No sound from speakers, '99 RAM 1500
Old May 17, 2004 | 09:36 PM
pautry's Avatar
pautry
Default No sound from speakers, '99 RAM 1500
My truck is a 1999 RAM 1500, and suddenly my speakers quit working. Has anyone had this problem and what did you do to correct it?
Old May 17, 2004 | 09:38 PM
shott8283's Avatar
shott8283
Default RE: No sound from speakers, '99 RAM 1500
stock head unit? and the what speakers? the tweeters on the pillars or the in dash ones?,....best idea....check the wiring...and if you blast the tunes....them tweeters (especially cheep stock ones) tend to blow quit easy...
Old May 17, 2004 | 09:40 PM
pautry's Avatar
pautry
It's a stock system with two door speakers, two in the back and the two small tweeters on the pillars. All quit working at once. I tried to check the wiring but everything is harnessed together in a way that makes it very difficult. Just wondering if maybe you know of a single point of failure that would cause all to shut off at the same time.
Old May 17, 2004 | 09:47 PM
shott8283's Avatar
shott8283
sounds like the head unit... head unit still has power?
Old May 17, 2004 | 10:05 PM
pautry's Avatar
pautry
Yes it does. I'm thinking that maybe the cable came loose or off in the back of the head unit, but I don't know how to get to it through the dash to check it.
Old May 17, 2004 | 10:17 PM
JCswm's Avatar
JCswm
Next to the power outlet/ cigarette lighter is one phillips head screw .... remove it
Pull on the dash..... It pops off.... you might have to unplug a few items after it pops off to remove it
then there's 4 phillips screws that hold the radio in..... It's that easy!!!!!
Those head units fail ALOT!!!
Old May 17, 2004 | 10:23 PM
pautry's Avatar
pautry
Thanks mucho! I'll give it a try.
-PA
