Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
1995 ram pu troubles
Old May 18, 2004 | 06:21 AM
IHScoutlvr's Avatar
IHScoutlvr
Default 1995 ram pu troubles
I have inharited a 1995 Dodge Ram 1500 2 wheel drive witha 5.2L(?)
engine. It looks like the 318cid. I collect IH trucks (Scouts, t-alls, pu, et..) so working on a "newer" truck is sorta different for me but since IH is 1/2 Dodge it's OK.
My problem is: in overdrive, at 1250 to 1750rpm the truck "shudders". that's about 55 to 65 mph.
when I take it off overdrive my rpm's increase to 2100 and the shuddering, while still there, is bearly noticeable.
What is the cause of this shuddering? I have changed the plugs and visually observed them sparking when I crank the engine.
I commute about 30 miles to work every day and my fuel expense is about $60 to $70 a week so If I can lower my rpms at hyway speeds it would help .
Is this a senser problem or a tranny problem or fuel pump or.....????
any help will be appreaceated and followed up.
thanks
