Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
1980 D-300 drive line vibration!!?
Old May 24, 2004 | 05:10 AM
DODGE80D300's Avatar
DODGE80D300
Default 1980 D-300 drive line vibration!!?
MY 1980 Dodge D-300 has a wierd vibration i can't seem to track down.
I have replaced:
tires.
rear rim's.
both U-jionts.
front wheel bearing's.
did a complete tune up,found that the distributor shaft was bent.
replaced dist.
what else can it be?? it start's around 57mph -63mph then goe's away.but it's so bad you can't see.
Vibration get's worse as it shift's,trans fluid clean and ful.
you can rev it up in park and it dose and if you rev it up in nuetral it dose it too. bad trans?? bad crank??[:@]
what else could it be??
Drive line:
3602bbl/727auto/4.11gear's Dana60 rear.
Anybody with any info Don't be scared to add your 2 cent's worth.......
Old May 24, 2004 | 02:20 PM
whitey's Avatar
whitey
Default RE: 1980 D-300 drive line vibration!!?
if it does it in park and neutral..... have you checked the vibration dampner on the front of the engine?
Old May 24, 2004 | 07:21 PM
DODGE80D300
No that i haven't checked it looked normale visually but if there is a way to test it or check it out let me know.....
